Salta al contenuto principale
Toshiba Satellite C55-A5100 Charging Port Jack Replacement
Cosa ti serve
  1. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Battery: passo 1, immagine 1 di 1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: passo 2, immagine 1 di 1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Optical Drive: passo 3, immagine 1 di 3 Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Optical Drive: passo 3, immagine 2 di 3 Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Optical Drive: passo 3, immagine 3 di 3
    • Place laptop with the bottom of it facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: passo 4, immagine 1 di 1
    • Remove the 4mm Phillips #1 screw on the side of the now exposed area.
  5. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: passo 5, immagine 1 di 1
    • Remove the disc drive from the device.
  6. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Hard Drive: passo 6, immagine 1 di 3 Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Hard Drive: passo 6, immagine 2 di 3 Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Hard Drive: passo 6, immagine 3 di 3
    • Place the laptop with the bottom facing up.
  7. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: passo 7, immagine 1 di 1
    • Using the Phillips #1 screwdriver, remove the 8mm screw that is holding the hard drive in place.
  8. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: passo 8, immagine 1 di 2 Toshiba Satellite C55-A5100 Charging Port Jack Replacement: passo 8, immagine 2 di 2
    • Use your finger to lift the hard drive up.
    • Pull out the hard drive to the right.
  9. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Charging Port Jack: passo 9, immagine 1 di 1
    • Unscrew all 15 screws that attach the back cover to the laptop.
    • Carefully pry the back cover off the laptop using the prying tools, starting from the hard drive side.
  10. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: passo 10, immagine 1 di 3 Toshiba Satellite C55-A5100 Charging Port Jack Replacement: passo 10, immagine 2 di 3 Toshiba Satellite C55-A5100 Charging Port Jack Replacement: passo 10, immagine 3 di 3
    • Locate the charging jack. Then carefully pull straight up.
    • Unplug the connector by pulling it towards the charging port side of the case, then carefully guide the wires away from the case.
Conclusione
Rei Rutkowski
Membro da: 11/26/18
184 Reputazione
2 Guide realizzate
IUPUI, Team S8-G8, Wilson Fall 2018 Membro di IUPUI, Team S8-G8, Wilson Fall 2018
IUPUI-WILSON-F18S8G8
4 Membri
6 Guide realizzate
Un commento
Hi. Correction on Step 9. Aside from the 15 black screws, I had to unscrew one silver screw. It sits right under the HDD.
Everything else was perfectly described.
Isidro B. - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,593
