Salta al contenuto principale
Toshiba Satellite A85-S107 15" Battery Replacement
Cosa ti serve
  1. Toshiba Satellite A85-S107 15" Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Power off the laptop.
    • Disconnect the power cable from the laptop. If you do not, electric shock may result.
  2. Toshiba Satellite A85-S107 15" Battery Replacement: passo 2, immagine 1 di 1
    • Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Unlock the battery by sliding the tab shown to the right
    • This tab will latch into place.
  3. Toshiba Satellite A85-S107 15" Battery Replacement: passo 3, immagine 1 di 2 Toshiba Satellite A85-S107 15" Battery Replacement: passo 3, immagine 2 di 2
    • Slide the tab shown to the left and remain holding it.
    • This tab does not lock into place like in the first step.
    • Place your thumb on the grips of the battery as shown.
    • While holding onto the grips, pull the battery towards you and away from the laptop.
Conclusione
Travis
Membro da: 04/13/13
31 Reputazione
5 Guide realizzate
Cal Poly, Team 10-38, Amido Spring 2013 Membro di Cal Poly, Team 10-38, Amido Spring 2013
CPSU-AMIDO-S13S10G38
4 Membri
24 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 566
