Salta al contenuto principale
Toshiba Satellite A660-ST3NX2X Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Unplug all cables and other devices from the computer before starting this replacement.
    • Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
  2. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 2, immagine 1 di 2 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 2, immagine 2 di 2
    • Locate the two sliding tabs on either side of the battery.
    • Using both hands, place one finger on each tab and slide them to the sides and away from each other.
  3. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 3, immagine 1 di 3 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 3, immagine 2 di 3 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 3, immagine 3 di 3
    • Pull the battery out, keeping the tabs pushed to the side.
    • The right tab on this laptop stayed pushed to the right without needing to be held in place.
  4. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 1
    • Unplug all devices from your computer and power down the device completely.
    • Flip the computer over so the screen is facing down.
    • In the image, the hard drive will appear to be in the top right corner where the box indicates.
  5. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 5, immagine 1 di 2 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 5, immagine 2 di 2
    • Use a J00 bit to unscrew the single 4mm screw that holds the hard drive cover in place.
  6. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 6, immagine 1 di 2 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 6, immagine 2 di 2
    • Remove the cover that holds the hard drive in place.
    • Remove the hard drive.
    • This computer contains no hard drive, therefore we are unable to show the physical removal of it.
Conclusione
Cassie Pickett
Membro da: 03/20/17
201 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 568
