Salta al contenuto principale
Toshiba Satellite A65-S126 Speaker Replacement
Cosa ti serve
  1. Toshiba Satellite A65-S126 Speaker Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Toshiba Satellite A65-S126 Speaker Replacement: passo 2, immagine 1 di 1
    • Gently lift the battery out of the computer.
  3. Toshiba Satellite A65-S126 Speaker Replacement, Upper Assembly: passo 3, immagine 1 di 1
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  4. Toshiba Satellite A65-S126 Speaker Replacement: passo 4, immagine 1 di 1
    • Remove the WIFI module cover. It will pull right off.
  5. Toshiba Satellite A65-S126 Speaker Replacement: passo 5, immagine 1 di 2 Toshiba Satellite A65-S126 Speaker Replacement: passo 5, immagine 2 di 2
    • Unplug the white and black wires from the WiFi module.
  6. Toshiba Satellite A65-S126 Speaker Replacement: passo 6, immagine 1 di 1
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
  7. Toshiba Satellite A65-S126 Speaker Replacement: passo 7, immagine 1 di 1
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
  8. Toshiba Satellite A65-S126 Speaker Replacement: passo 8, immagine 1 di 1
    • Use the plastic opening tool to pry the two halves apart.
  9. Toshiba Satellite A65-S126 Speaker Replacement, Speaker: passo 9, immagine 1 di 2 Toshiba Satellite A65-S126 Speaker Replacement, Speaker: passo 9, immagine 2 di 2
    • Locate the plug for the speaker wires on the bottom of the laptop.
  10. Toshiba Satellite A65-S126 Speaker Replacement: passo 10, immagine 1 di 1
    • Unplug the speaker wire connector.
  11. Toshiba Satellite A65-S126 Speaker Replacement: passo 11, immagine 1 di 1
    • Remove the speakers by sliding them straight up. They should slide out with ease.
Conclusione
Cole Uhland
Membro da: 09/30/13
216 Reputazione
2 Guide realizzate
Cal Poly, Team 14-8, Forte Fall 2013 Membro di Cal Poly, Team 14-8, Forte Fall 2013
CPSU-FORTE-F13S14G8
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 581
