Salta al contenuto principale
Toshiba Satellite A305-S6848 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite A305-S6848 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Close laptop and turn it upside down.
  2. Toshiba Satellite A305-S6848 Keyboard Replacement: passo 2, immagine 1 di 1
    • Move the left locking hatch to the left.
    • Hold the right spring latch to the right.
  3. Toshiba Satellite A305-S6848 Keyboard Replacement: passo 3, immagine 1 di 1
    • Carefully remove the battery from the laptop.
  4. Toshiba Satellite A305-S6848 Keyboard Replacement, Keyboard: passo 4, immagine 1 di 1
    • The keyboard is held in by a locking strip between the screen and the keyboard.
  5. Toshiba Satellite A305-S6848 Keyboard Replacement: passo 5, immagine 1 di 1
    • Use the metal spudger to pry out the right portion of the locking piece just above the DEL key.
  6. Toshiba Satellite A305-S6848 Keyboard Replacement: passo 6, immagine 1 di 1
    • Use your hand to take out locking strip from the right portion that was pried out.
  7. Toshiba Satellite A305-S6848 Keyboard Replacement: passo 7, immagine 1 di 2 Toshiba Satellite A305-S6848 Keyboard Replacement: passo 7, immagine 2 di 2
    • Use the Phillip's #0 screwdriver to take out the two 5.8 mm Phillip's #0 screws from the top right and left corners of the keyboard.
  8. Toshiba Satellite A305-S6848 Keyboard Replacement: passo 8, immagine 1 di 2 Toshiba Satellite A305-S6848 Keyboard Replacement: passo 8, immagine 2 di 2
    • Lift the keyboard up slightly. Use caution as the keyboard ribbon cable is still attached below the keyboard.
    • Disconnect the keyboard by flipping the locking clip upwards.
Conclusione
Joshua E Hong
Membro da: 11/06/17
449 Reputazione
4 Guide realizzate
Baylor, Team S8-G1, Johnson Fall 2017 Membro di Baylor, Team S8-G1, Johnson Fall 2017
BU-JOHNSON-F17S8G1
2 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 642
