Salta al contenuto principale
Toshiba Satellite A305-S6848 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite A305-S6848 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 2 Toshiba Satellite A305-S6848 Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Remove the 5.8mm Phillip's #0 screw with Phillip's #0 screwdriver while prying plastic covering up with metal spudger.
  2. Toshiba Satellite A305-S6848 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Remove plastic covering.
    • Pull up the silver tab to remove the hard drive from the slot.
Conclusione
Joshua E Hong
Membro da: 11/06/17
449 Reputazione
4 Guide realizzate
Baylor, Team S8-G1, Johnson Fall 2017 Membro di Baylor, Team S8-G1, Johnson Fall 2017
BU-JOHNSON-F17S8G1
2 Membri
12 Guide realizzate
Un commento
Note: There are two hard drives in this machine. One has a single screw holding it in place within the compartment, and is very straightforward. The other has two screws. After removing the latter, the drive compartment pulls out, sliding over the now empty screw holes.
Kim McCoy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,153
