Salta al contenuto principale
Toshiba Satellite A215-S7425 Optical Drive Replacement
Cosa ti serve
  1. Toshiba Satellite A215-S7425 Optical Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the computer.
    • Disconnect the charging cable from computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Toshiba Satellite A215-S7425 Optical Drive Replacement: passo 2, immagine 1 di 1
    • Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
    • Latch #1 will click over and stay while latch #2 will have to be held for battery to release.
  3. Toshiba Satellite A215-S7425 Optical Drive Replacement: passo 3, immagine 1 di 1
    • Gently lift and pull the battery out of the device.
  4. Toshiba Satellite A215-S7425 Optical Drive Replacement, RAM: passo 4, immagine 1 di 1
    • Locate the RAM vented plastic cover in the center of the device.
  5. Toshiba Satellite A215-S7425 Optical Drive Replacement: passo 5, immagine 1 di 2 Toshiba Satellite A215-S7425 Optical Drive Replacement: passo 5, immagine 2 di 2
    • Loosen 1 Phillips 4.2 mm size captive screw and lift cover off device to expose 2 RAM sticks.
  6. Toshiba Satellite A215-S7425 Optical Drive Replacement: passo 6, immagine 1 di 3 Toshiba Satellite A215-S7425 Optical Drive Replacement: passo 6, immagine 2 di 3 Toshiba Satellite A215-S7425 Optical Drive Replacement: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    • Locate 2 metal pinchers on either side of the 1st RAM stick.
    • Use a finger from each hand to push the 2 pinchers simultaneously away from the stick of RAM and towards the exterior of the case.
    • The RAM stick will automatically rise up. Gently pull out the RAM stick with one hand.
    • The use of a anti-static wrist strap while working with the RAM is advise to prevent electrostatic discharge(ESD) from damaging the RAM.
  7. Toshiba Satellite A215-S7425 Optical Drive Replacement: passo 7, immagine 1 di 3 Toshiba Satellite A215-S7425 Optical Drive Replacement: passo 7, immagine 2 di 3 Toshiba Satellite A215-S7425 Optical Drive Replacement: passo 7, immagine 3 di 3
    • To remove the 2nd RAM stick, repeat previous steps.
    • You will be unable to remove 2nd RAM stick if the first one is not removed first.
  8. Toshiba Satellite A215-S7425 Optical Drive Replacement, Optical Drive: passo 8, immagine 1 di 1
    • Locate and remove 1 Phillips 4.2 mm size screw along right side of RAM container.
    • Tweezers may be needed to lift out the screw.
  9. Toshiba Satellite A215-S7425 Optical Drive Replacement: passo 9, immagine 1 di 2 Toshiba Satellite A215-S7425 Optical Drive Replacement: passo 9, immagine 2 di 2
    • Push down metal rod until optical drive pops out from its container on the side of the device.
    • To avoid damage to your RAM, make sure RAM is removed and out of the way before beginning this step.
Conclusione
Marianne
Membro da: 09/08/14
647 Reputazione
6 Guide realizzate
Pasco Hernando, Team 5-2, Prince Fall 2014 Membro di Pasco Hernando, Team 5-2, Prince Fall 2014
PHSC-PRINCE-F14S5G2
10 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 16
Tutti i Tempi: 393
