Salta al contenuto principale
Toshiba Satellite A215-S4757 Display Screen Replacement
Cosa ti serve
  1. Toshiba Satellite A215-S4757 Display Screen Replacement, Display Screen: passo 1, immagine 1 di 2 Toshiba Satellite A215-S4757 Display Screen Replacement, Display Screen: passo 1, immagine 2 di 2
    • First, remove the four rubber screw coverings located at the top corners and bottom corners of the screen.
    • Remove the four screws underneath each cover and place them somewhere secure.
  2. Toshiba Satellite A215-S4757 Display Screen Replacement: passo 2, immagine 1 di 3 Toshiba Satellite A215-S4757 Display Screen Replacement: passo 2, immagine 2 di 3 Toshiba Satellite A215-S4757 Display Screen Replacement: passo 2, immagine 3 di 3
    • Remove the plastic paneling around the screen, and at the bottom of the display.
    • You may need a plastic opening tool to pry the back crease open.
  3. Toshiba Satellite A215-S4757 Display Screen Replacement: passo 3, immagine 1 di 3 Toshiba Satellite A215-S4757 Display Screen Replacement: passo 3, immagine 2 di 3 Toshiba Satellite A215-S4757 Display Screen Replacement: passo 3, immagine 3 di 3
    • Remove the three screws on each side of the display, and place them somewhere secure.
  4. Toshiba Satellite A215-S4757 Display Screen Replacement: passo 4, immagine 1 di 2 Toshiba Satellite A215-S4757 Display Screen Replacement: passo 4, immagine 2 di 2
    • Gently move the display forward so you can see the back of the component.
  5. Toshiba Satellite A215-S4757 Display Screen Replacement: passo 5, immagine 1 di 3 Toshiba Satellite A215-S4757 Display Screen Replacement: passo 5, immagine 2 di 3 Toshiba Satellite A215-S4757 Display Screen Replacement: passo 5, immagine 3 di 3
    • On the back of the display, there is a wire that is plugged in to the display and secured with tape.
    • Gently lift the tape, leaving it attached to the wire.
    • Pull the wire out of its socket in the display backing.
    • The display is now fully detached!
Conclusione
Jacob Brown
Membro da: 10/10/16
409 Reputazione
3 Guide realizzate
Texas Tech, Team 12-2, Bennett Fall 2016 Membro di Texas Tech, Team 12-2, Bennett Fall 2016
TTU-BENNETT-F16S12G2
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 380
