Salta al contenuto principale
Toshiba Satellite A215-S4757 Battery Replacement
Cosa ti serve
  1. Toshiba Satellite A215-S4757 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Before removing anything on your Toshiba Satellite, make sure your computer is turned off, and your power adapter is not plugged in.
  2. Toshiba Satellite A215-S4757 Battery Replacement: passo 2, immagine 1 di 1
    • Turn your Satellite over and locate your battery.
    • Locate the battery clips.
    • With your thumb and pointer fingers slide them outward at the same time, and hold.
  3. Toshiba Satellite A215-S4757 Battery Replacement: passo 3, immagine 1 di 2 Toshiba Satellite A215-S4757 Battery Replacement: passo 3, immagine 2 di 2
    • Gently lift the battery out of its socket until completely removed and release the clips.
    • Your battery is now removed from your computer.
Conclusione
Altre 2 persone hanno completato questa guida.
Jacob Brown
Membro da: 10/10/16
409 Reputazione
3 Guide realizzate
Texas Tech, Team 12-2, Bennett Fall 2016 Membro di Texas Tech, Team 12-2, Bennett Fall 2016
TTU-BENNETT-F16S12G2
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 345
