Salta al contenuto principale
Toshiba Satellite A210 Optical Disc Drive Replacement
Cosa ti serve
  1. Toshiba Satellite A210 Optical Disc Drive Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite A210 Optical Disc Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Optical Disc Drive Replacement: passo 2, immagine 1 di 2 Toshiba Satellite A210 Optical Disc Drive Replacement: passo 2, immagine 2 di 2
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Optical Disc Drive Replacement, RAM: passo 3, immagine 1 di 2 Toshiba Satellite A210 Optical Disc Drive Replacement, RAM: passo 3, immagine 2 di 2
    • Remove the screw holding the RAM cover with a PH1 screwdriver.
    • Remove the RAM cover.
  4. Toshiba Satellite A210 Optical Disc Drive Replacement: passo 4, immagine 1 di 3 Toshiba Satellite A210 Optical Disc Drive Replacement: passo 4, immagine 2 di 3 Toshiba Satellite A210 Optical Disc Drive Replacement: passo 4, immagine 3 di 3
    • Push outwards on the metal tabs to release the RAM.
    • Remove the RAM. Some force may be needed.
    • Be careful not to touch the gold pins on the RAM chips as there may be a build-up of static electricity. This can fry the parts of the chip that houses memory.
  5. Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: passo 5, immagine 1 di 3 Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: passo 5, immagine 2 di 3 Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: passo 5, immagine 3 di 3
    • Use a PH0 screwdriver to remove the screw holding the optical drive in place.
    • Using your index finger, push the metal tab inside the RAM bay which is located directly underneath the screw-hole.
    • The optical drive will then slide out.
Conclusione
Cal Poly, Team 17-5, Regan Spring 2013 Membro di Cal Poly, Team 17-5, Regan Spring 2013
CPSU-REGAN-S13S17G5
4 Membri
18 Guide realizzate
Un commento
Question : if i this will my screen start working ng again
jessica johnson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,616
