Salta al contenuto principale
Toshiba Satellite A210 Motherboard Replacement
Cosa ti serve
  1. Toshiba Satellite A210 Motherboard Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite A210 Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Motherboard Replacement: passo 2, immagine 1 di 2 Toshiba Satellite A210 Motherboard Replacement: passo 2, immagine 2 di 2
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Motherboard Replacement, RAM: passo 3, immagine 1 di 2 Toshiba Satellite A210 Motherboard Replacement, RAM: passo 3, immagine 2 di 2
    • Remove the screw holding the RAM cover with a PH1 screwdriver.
    • Remove the RAM cover.
  4. Toshiba Satellite A210 Motherboard Replacement: passo 4, immagine 1 di 3 Toshiba Satellite A210 Motherboard Replacement: passo 4, immagine 2 di 3 Toshiba Satellite A210 Motherboard Replacement: passo 4, immagine 3 di 3
    • Push outwards on the metal tabs to release the RAM.
    • Remove the RAM. Some force may be needed.
    • Be careful not to touch the gold pins on the RAM chips as there may be a build-up of static electricity. This can fry the parts of the chip that houses memory.
  5. Toshiba Satellite A210 Motherboard Replacement, Optical Disc Drive: passo 5, immagine 1 di 3 Toshiba Satellite A210 Motherboard Replacement, Optical Disc Drive: passo 5, immagine 2 di 3 Toshiba Satellite A210 Motherboard Replacement, Optical Disc Drive: passo 5, immagine 3 di 3
    • Use a PH0 screwdriver to remove the screw holding the optical drive in place.
    • Using your index finger, push the metal tab inside the RAM bay which is located directly underneath the screw-hole.
    • The optical drive will then slide out.
  6. Toshiba Satellite A210 Motherboard Replacement, Keyboard: passo 6, immagine 1 di 1
    • Unscrew the 4 highlighted screws with a PH1 screwdriver.
  7. Toshiba Satellite A210 Motherboard Replacement: passo 7, immagine 1 di 3 Toshiba Satellite A210 Motherboard Replacement: passo 7, immagine 2 di 3 Toshiba Satellite A210 Motherboard Replacement: passo 7, immagine 3 di 3
    • Orient the laptop so that the screen is open and facing you.
    • Slide the plastic opening tool underneath the top edge of the black plastic insert.
    • Pull it off and set aside.
  8. Toshiba Satellite A210 Motherboard Replacement: passo 8, immagine 1 di 2 Toshiba Satellite A210 Motherboard Replacement: passo 8, immagine 2 di 2
    • Remove the 2 PH1 screws.
    • Lift the keyboard from the top being carful not to remove it fully. There is still a ribbon cable that connects the keyboard to the laptop.
  9. Toshiba Satellite A210 Motherboard Replacement: passo 9, immagine 1 di 1
    • Disconnect the keyboard ribbon cable and remove the keyboard from the laptop.
  10. Toshiba Satellite A210 Motherboard Replacement, Fan: passo 10, immagine 1 di 1
    • Close the laptop and flip it over.
    • Unscrew the 11 yellow circled screws with a PH1 screwdriver. These screws are larger in size.
    • Unscrew the 2 red and yellow circled screws with a PH1 screwdriver. These screws are shorter and thicker than the previous.
    • Unscrew the 1 green and yellow circled screw with a PH1 screwdriver. This screw is longer and thinner than the previous.
  11. Toshiba Satellite A210 Motherboard Replacement: passo 11, immagine 1 di 3 Toshiba Satellite A210 Motherboard Replacement: passo 11, immagine 2 di 3 Toshiba Satellite A210 Motherboard Replacement: passo 11, immagine 3 di 3
    • Flip the laptop over and open it so that the screen is facing you.
    • Locate the hinges on either side of the screen, which secure the display to the body of the laptop.
    • Unscrew the 2 screws in each hinge with a PH1 screwdriver.
    • The display is no longer connected to the laptop and could fall. Be careful not to drop it during the next steps.
  12. Toshiba Satellite A210 Motherboard Replacement: passo 12, immagine 1 di 3 Toshiba Satellite A210 Motherboard Replacement: passo 12, immagine 2 di 3 Toshiba Satellite A210 Motherboard Replacement: passo 12, immagine 3 di 3
    • Unfasten the connectors from the highlighted locations.
    • Disconnect by gently pulling on the fasteners which connect the wires to the laptop.
    • Pulling directly on the wires could cause permanent damage to the connectors or the wires themselves.
    • Unscrew the screw indicated by the yellow circle.
  13. Toshiba Satellite A210 Motherboard Replacement: passo 13, immagine 1 di 2 Toshiba Satellite A210 Motherboard Replacement: passo 13, immagine 2 di 2
    • Slide the plastic opening tool underneath the edges of the upper casing, which is shown in the images.
  14. Toshiba Satellite A210 Motherboard Replacement: passo 14, immagine 1 di 1
    • The LCD screen can now be removed from the laptop.
    • Lift the upper plastic casing and remove it from the lower half of the laptop.
  15. Toshiba Satellite A210 Motherboard Replacement: passo 15, immagine 1 di 3 Toshiba Satellite A210 Motherboard Replacement: passo 15, immagine 2 di 3 Toshiba Satellite A210 Motherboard Replacement: passo 15, immagine 3 di 3
    • Unfasten the two connections shown.
    • Unscrew the two screws securing the fan to the laptop. Use a PH1 for the screw that is adjacent to the speaker and a PH0 for the other screw.
    • Lift up the fan and pull the black plastic tab away from the fan housing. Remove the fan.
    • Do not remove the metal fan housing. It is taped to a metal heat-sink and should not be removed.
  16. Toshiba Satellite A210 Motherboard Replacement, Motherboard: passo 16, immagine 1 di 1
    • First, remove the one screw with a PH1 screwdriver.
    • Next, remove the black connector marked by the yellow box.
  17. Toshiba Satellite A210 Motherboard Replacement: passo 17, immagine 1 di 2 Toshiba Satellite A210 Motherboard Replacement: passo 17, immagine 2 di 2
    • Gently pull the the small white ribbon cable from its housing on the motherboard.
    • Locate and unfasten the small white clip from the motherboard near the bottom right.
  18. Toshiba Satellite A210 Motherboard Replacement: passo 18, immagine 1 di 3 Toshiba Satellite A210 Motherboard Replacement: passo 18, immagine 2 di 3 Toshiba Satellite A210 Motherboard Replacement: passo 18, immagine 3 di 3
    • Disconnect the two white fasteners that connect the speakers to the motherboard.
  19. Toshiba Satellite A210 Motherboard Replacement: passo 19, immagine 1 di 3 Toshiba Satellite A210 Motherboard Replacement: passo 19, immagine 2 di 3 Toshiba Satellite A210 Motherboard Replacement: passo 19, immagine 3 di 3
    • Gently slide the plastic opening tool underneath and around the motherboard.
    • Do not force the motherboard out. If the motherboard breaks, it is not repairable. You will have to buy a new one.
    • After the motherboard is free of the plastic casing, do not pull it all the way out. There is still a connector on the underside of it.
    • Remove the connector on the underside using your fingers.
Conclusione
Altre 8 persone hanno completato questa guida.
Devin
Membro da: 04/11/13
66 Reputazione
3 Guide realizzate
Cal Poly, Team 17-5, Regan Spring 2013 Membro di Cal Poly, Team 17-5, Regan Spring 2013
CPSU-REGAN-S13S17G5
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 54
Tutti i Tempi: 8,145
