Salta al contenuto principale
Toshiba Satellite A205-S4577 USB 3.0 ports Replacement
Cosa ti serve
  1. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the two sliding locks indicated in the photo.
    • Slide the right lock (labeled "1") to the right. It will remain in the unlocked position.
    • Slide the left lock (labeled "2") to the left and hold it in place.
  2. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: passo 2, immagine 1 di 1
    • While holding the left lock, place your finger in the indentation next to the battery and lift the battery out.
  3. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, Speaker Cover: passo 3, immagine 1 di 3 Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, Speaker Cover: passo 3, immagine 2 di 3 Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, Speaker Cover: passo 3, immagine 3 di 3
    • Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head.
  4. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: passo 4, immagine 1 di 1
    • With your hands, grasp the speaker cover on the edge nearest to the screen.
    • Pry the speaker cover upward.
  5. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: passo 5, immagine 1 di 1
    • Remove the speaker cover. Your laptop will look like this photo when the speaker cover has been removed.
  6. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, Front Cover: passo 6, immagine 1 di 1
    • Locate the screws that are shown in the image.
    • Remove the fourteen 6mm button-head screws with a Phillips 00 Screwdriver.
  7. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: passo 7, immagine 1 di 2 Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: passo 7, immagine 2 di 2
    • Lift up on the front cover to remove it.
  8. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement, USB 2.0 Ports: passo 8, immagine 1 di 1
    • Locate the USB 2.0 cable on the bottom right corner of the laptop.
  9. Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: passo 9, immagine 1 di 2 Toshiba Satellite A205-S4577 USB 3.0 ports Replacement: passo 9, immagine 2 di 2
    • Locate the white slot on the left side of the USB 2.0 wire.
    • Carefully detach the wire by pulling the cable to the right of the slot.
Conclusione
Curtis
Membro da: 04/18/13
109 Reputazione
1 Guida realizzata
Cal Poly, Team 17-6, Regan Spring 2013 Membro di Cal Poly, Team 17-6, Regan Spring 2013
CPSU-REGAN-S13S17G6
5 Membri
33 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 32
Tutti i Tempi: 1,904
