Introduzione
This guide will show how to properly remove the motherboard from the laptop in order to replace or inspect the motherboard.
Cosa ti serve
Locate the two sliding locks indicated in the photo.
Slide the right lock (labeled "1") to the right. It will remain in the unlocked position.
Slide the left lock (labeled "2") to the left and hold it in place.
Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head.
Slightly lift and ease the keyboard forward, toward the screen, until the tabs clear the case.
When all the tabs are free, slowly lift the bottom of the keyboard while keeping the top of the keyboard angled down. Continue to carefully rotate the keyboard over until you can access the ribbon cable that is still connecting it to the computer.
The Ribbon Cable must be disconnected here to release the keyboard.
Using a plastic splunger or the tip of your screwdriver gently push upward on the two black tabs securing the connection.
When the black plastic bar running across the cable is unseated you can slowly and carefully pull the ribbon cable free.
You can now lift and remove the keyboard.
Locate the gray wire on the right.
Detach the white end by gently pulling each socket away from the other.
Once all the wires are detached and screws are removed, pull up on the monitor to remove it.
There were two additional screws on the back of the laptop I had to remove to get the screen off.
Locate the screws that are shown in the image.
Remove the fourteen 6mm button-head screws with a Phillips 00 Screwdriver.
Lift up on the front cover to remove it.
There was an additional screw in the front cover to the right of the wireless card that I had to remove; it was already gone in earlier pictures in the walkthrough
Locate the 6mm flat-head screw in the top right corner of the bottom of the laptop.
Remove this screw with the Phillips 00 Screwdriver.
Locate the 4mm flat-head screw. Remove it using the Phillips 00 Screwdriver.
Locate the two black and red wires on each side of the motherboard.
Slowly pull back on the cables away from the motherboard to detach them from their connector slots.
Altre 8 persone hanno completato questa guida.
