Salta al contenuto principale
Toshiba Satellite A205-S4577 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite A205-S4577 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Locate the hard drive cover on the bottom, left-hand corner of your laptop.
    • Using a Phillips #00 screwdriver, remove both 4mm screws.
  2. Toshiba Satellite A205-S4577 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Lift the cover to reveal the old hard drive.
    • Carefully detach the hard drive from the SATA/Power connector.
  3. Toshiba Satellite A205-S4577 Hard Drive Replacement: passo 3, immagine 1 di 1
    • After removing the old hard drive, place the new hard drive into the bay, and firmly reattach it to the SATA/Power connector.
Conclusione
Cal Poly, Team 17-6, Regan Spring 2013 Membro di Cal Poly, Team 17-6, Regan Spring 2013
CPSU-REGAN-S13S17G6
5 Membri
33 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 29
Tutti i Tempi: 2,536
