Salta al contenuto principale
Toshiba Satellite A105-S4284 RAM Replacement
Cosa ti serve
  1. Toshiba Satellite A105-S4284 RAM Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite A105-S4284 RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284 RAM Replacement, RAM: passo 2, immagine 1 di 2 Toshiba Satellite A105-S4284 RAM Replacement, RAM: passo 2, immagine 2 di 2
    • Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver.
    • You will not be able to remove the screw from the panel as it is designed to stay in the panel.
  3. Toshiba Satellite A105-S4284 RAM Replacement: passo 3, immagine 1 di 2 Toshiba Satellite A105-S4284 RAM Replacement: passo 3, immagine 2 di 2
    • With your fingers, carefully remove the middle panel by lifting the edge with the indent.
  4. Toshiba Satellite A105-S4284 RAM Replacement: passo 4, immagine 1 di 3 Toshiba Satellite A105-S4284 RAM Replacement: passo 4, immagine 2 di 3 Toshiba Satellite A105-S4284 RAM Replacement: passo 4, immagine 3 di 3
    • Using your fingers, release the tabs on both ends of the RAM.
    • Pull the RAM out.
    • The other RAM is released in the same manner.
Conclusione
pfedigan
Membro da: 04/12/13
11 Reputazione
4 Guide realizzate
Cal Poly, Team 2-23, Maness Spring 2013 Membro di Cal Poly, Team 2-23, Maness Spring 2013
CPSU-MANESS-S13S2G23
4 Membri
13 Guide realizzate
Un commento
how to remove a bios passcode off of a Toshiba Satellite a105 s4374 laptop
simeon cole - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,154
