Salta al contenuto principale
Toshiba Satellite A105-S4284 Disc Drive Replacement
Cosa ti serve
  1. Toshiba Satellite A105-S4284 Disc Drive Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite A105-S4284 Disc Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284 Disc Drive Replacement, Disc Drive: passo 2, immagine 1 di 2 Toshiba Satellite A105-S4284 Disc Drive Replacement, Disc Drive: passo 2, immagine 2 di 2
    • Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver.
    • You will not be able to remove the screw from the panel as it is designed to stay in the panel.
  3. Toshiba Satellite A105-S4284 Disc Drive Replacement: passo 3, immagine 1 di 2 Toshiba Satellite A105-S4284 Disc Drive Replacement: passo 3, immagine 2 di 2
    • With your fingers, carefully remove the middle panel by lifting the edge with the indent.
  4. Toshiba Satellite A105-S4284 Disc Drive Replacement: passo 4, immagine 1 di 2 Toshiba Satellite A105-S4284 Disc Drive Replacement: passo 4, immagine 2 di 2
    • Remove the 4.0 mm screw above the small metal tab with a Phillips 00 screwdriver.
  5. Toshiba Satellite A105-S4284 Disc Drive Replacement: passo 5, immagine 1 di 2 Toshiba Satellite A105-S4284 Disc Drive Replacement: passo 5, immagine 2 di 2
    • Push down on the metal tab under the cover with the plastic opening tool and push the disc drive partially out.
    • Grab the drive and pull it out of the laptop.
Conclusione
pfedigan
Membro da: 04/12/13
11 Reputazione
4 Guide realizzate
Cal Poly, Team 2-23, Maness Spring 2013 Membro di Cal Poly, Team 2-23, Maness Spring 2013
CPSU-MANESS-S13S2G23
4 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 848
