Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
  1. Flip the laptop over so it is rightside up, and open the laptop all the way so that the screen is horizontal.
    • Flip the laptop over so it is rightside up, and open the laptop all the way so that the screen is horizontal.
  2. Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker. Use the plastic opening tool to pop off tabs along the length of this panel. This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
    • Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
    • Use the plastic opening tool to pop off tabs along the length of this panel.
    • This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
  3. Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver. Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
    • Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Lift the keyboard gently from the side closest the screen. Pull out the ribbon connecting the keyboard to the laptop. Pull out the ribbon connecting the keyboard to the laptop.
    • Lift the keyboard gently from the side closest the screen.
    • Pull out the ribbon connecting the keyboard to the laptop.
  6. Disconnect wire attaching LCD to motherboard Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
    • Disconnect wire attaching LCD to motherboard
    • Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers
    • Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
  7. Remove the seventeen 4.5mm phillips screws on the bottom of the laptop. Using the pry tool separate the two halves of the laptop base.
    • Remove the seventeen 4.5mm phillips screws on the bottom of the laptop.
    • Using the pry tool separate the two halves of the laptop base.
    • Use caution when separating the laptop halves as they are still connected by two ribbon cables.
  8. Lift the top half of the case enough to get your hand beneath it, and then remove the two ribbon cables that connect it to the motherboard. Lift the top half of the case enough to get your hand beneath it, and then remove the two ribbon cables that connect it to the motherboard.
    • Lift the top half of the case enough to get your hand beneath it, and then remove the two ribbon cables that connect it to the motherboard.
Conclusione
Josh
Membro da: 12/03/2014
625 Reputazione
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 703
