Salta al contenuto principale
Toshiba Satellite A105-S4284 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite A105-S4284  Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite A105-S4284  Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284  Hard Drive Replacement, Hard Drive: passo 2, immagine 1 di 3 Toshiba Satellite A105-S4284  Hard Drive Replacement, Hard Drive: passo 2, immagine 2 di 3 Toshiba Satellite A105-S4284  Hard Drive Replacement, Hard Drive: passo 2, immagine 3 di 3
    • Turn the laptop around 180 degrees.
    • Unscrew the 4 mm screw with the Philips #1 screwdriver.
    • Lift and remove the hard drive cover.
  3. Toshiba Satellite A105-S4284  Hard Drive Replacement: passo 3, immagine 1 di 3 Toshiba Satellite A105-S4284  Hard Drive Replacement: passo 3, immagine 2 di 3 Toshiba Satellite A105-S4284  Hard Drive Replacement: passo 3, immagine 3 di 3
    • Pull on the rubber tab to slide the hard drive to the left.
    • Pick up the near side of the hard drive and pull it out the back.
Conclusione
pfedigan
Membro da: 04/12/13
11 Reputazione
4 Guide realizzate
Cal Poly, Team 2-23, Maness Spring 2013 Membro di Cal Poly, Team 2-23, Maness Spring 2013
CPSU-MANESS-S13S2G23
4 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,521
