Salta al contenuto principale
Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement
Cosa ti serve
  1. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Battery: passo 1, immagine 2 di 2
    • To prevent electrical shock, make sure the computer is turned off; and disconnect the power adapter from the computer and electrical outlet prior to beginning any repairs on this device.
    • Turn the laptop upside down with the battery facing you.
  2. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: passo 2, immagine 1 di 3 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: passo 2, immagine 2 di 3 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: passo 2, immagine 3 di 3
    • Slide both the left and right battery release tabs outwards away from center of the laptop.
    • Right release tab will remain locked in place.
    • While still holding the left release tab, slide the battery towards you using your right hand.
    • Fully remove the battery from the laptop.
  3. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Optical Disk Drive (DVD/CD-ROM): passo 3, immagine 1 di 2 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Optical Disk Drive (DVD/CD-ROM): passo 3, immagine 2 di 2
    • Turn the laptop around with the battery slot facing away from you.
    • Remove the 5.0 mm screw that is holding the optical disk drive internally in place using the Phillips #1 screwdriver.
  4. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: passo 4, immagine 1 di 3 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: passo 4, immagine 2 di 3 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: passo 4, immagine 3 di 3
    • Turn the laptop back over (cover-side up) with the optical disk drive on the right side.
    • With the plastic opening tool, pry the drive out from the top.
    • Using the opening tool, pull the drive out of the drive bay.
Conclusione
To reassemble your device after replacing the DVD SuperMulti drive, follow these instructions in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 16
Tutti i Tempi: 571
