Salta al contenuto principale
Toshiba Satellite A105-S4074 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite A105-S4074 Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite A105-S4074 Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • To prevent electrical shock, make sure the computer is turned off; and disconnect the power adapter from the computer and electrical outlet prior to beginning any repairs on this device.
    • Turn the laptop upside down with the battery facing you.
  2. Toshiba Satellite A105-S4074 Hard Drive Replacement: passo 2, immagine 1 di 3 Toshiba Satellite A105-S4074 Hard Drive Replacement: passo 2, immagine 2 di 3 Toshiba Satellite A105-S4074 Hard Drive Replacement: passo 2, immagine 3 di 3
    • Slide both the left and right battery release tabs outwards away from center of the laptop.
    • Right release tab will remain locked in place.
    • While still holding the left release tab, slide the battery towards you using your right hand.
    • Fully remove the battery from the laptop.
  3. Toshiba Satellite A105-S4074 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 3 Toshiba Satellite A105-S4074 Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 3 Toshiba Satellite A105-S4074 Hard Drive Replacement, Hard Drive: passo 3, immagine 3 di 3
    • Turn the laptop around so that the battery slot is facing away from you, and locate the hard drive access panel in the lower left-hand corner.
    • Locate the hard drive access panel in the lower left-hand corner on the bottom of the laptop, and loosen the 4.0 mm screw in the top center of the panel using the Phillips #1 screwdriver.
    • This is a captive screw and will remain intact with the panel.
    • Carefully remove the panel with your fingers by lifting the edge at the indent.
  4. Toshiba Satellite A105-S4074 Hard Drive Replacement: passo 4, immagine 1 di 3 Toshiba Satellite A105-S4074 Hard Drive Replacement: passo 4, immagine 2 di 3 Toshiba Satellite A105-S4074 Hard Drive Replacement: passo 4, immagine 3 di 3
    • You should now have full access to the hard drive.
    • Slide the hard drive to the left.
    • Gently lift the hard drive from the side closest to you and remove it.
Conclusione
To reassemble your device after replacing the hard drive, follow these instructions in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,395
