Salta al contenuto principale
Toshiba Satellite A105-S4074 Battery Replacement
Cosa ti serve
  1. Toshiba Satellite A105-S4074 Battery Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite A105-S4074 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • To prevent electrical shock, make sure the computer is turned off; and disconnect the power adapter from the computer and electrical outlet prior to beginning any repairs on this device.
    • Turn the laptop upside down with the battery facing you.
  2. Toshiba Satellite A105-S4074 Battery Replacement: passo 2, immagine 1 di 3 Toshiba Satellite A105-S4074 Battery Replacement: passo 2, immagine 2 di 3 Toshiba Satellite A105-S4074 Battery Replacement: passo 2, immagine 3 di 3
    • Slide both the left and right battery release tabs outwards away from center of the laptop.
    • Right release tab will remain locked in place.
    • While still holding the left release tab, slide the battery towards you using your right hand.
    • Fully remove the battery from the laptop.
Conclusione
To reassemble your device after inserting the replacement battery, follow these instructions in reverse order.
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 405
