Salta al contenuto principale
Toshiba Satellite A105-S4011 RAM Replacement
Cosa ti serve
  1. Toshiba Satellite A105-S4011 RAM Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite A105-S4011 RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
  2. Toshiba Satellite A105-S4011 RAM Replacement: passo 2, immagine 1 di 2 Toshiba Satellite A105-S4011 RAM Replacement: passo 2, immagine 2 di 2
    • Hold the release switch and pull out the battery towards you.
  3. Toshiba Satellite A105-S4011 RAM Replacement, RAM: passo 3, immagine 1 di 1
    • Locate the screw that is holding the back cover in place and, unscrew it using the #1 Phillips Screwdriver.
    • This screw cannot be taken out, it is a "captive" screw.
  4. Toshiba Satellite A105-S4011 RAM Replacement: passo 4, immagine 1 di 1
    • Using a plastic opening tool, pop off the back cover. Your going to insert the tool into the small slit located on the back cover piece.
    • Be careful when prying the back cover off because you may damage the cover or crack the plastic.
  5. Toshiba Satellite A105-S4011 RAM Replacement: passo 5, immagine 1 di 2 Toshiba Satellite A105-S4011 RAM Replacement: passo 5, immagine 2 di 2
    • Locate the RAM (green module pictured here), and the two prongs on each side of the module. Press the two prongs outwardly, and pull out the RAM module.
    • Grounding yourself may be a good idea before actually touching the RAM module. This entails touching a conductive metal in order to remove any excess static energy in your body.
Conclusione
Cal Poly, Team 4-14, Maness Spring 2013 Membro di Cal Poly, Team 4-14, Maness Spring 2013
CPSU-MANESS-S13S4G14
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,308
