Salta al contenuto principale
Toshiba Satellite A105-S4011 Battery Replacement
  1. Toshiba Satellite A105-S4011 Battery Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite A105-S4011 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
  2. Toshiba Satellite A105-S4011 Battery Replacement: passo 2, immagine 1 di 2 Toshiba Satellite A105-S4011 Battery Replacement: passo 2, immagine 2 di 2
    • Hold the release switch and pull out the battery towards you.
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team 4-14, Maness Spring 2013 Membro di Cal Poly, Team 4-14, Maness Spring 2013
CPSU-MANESS-S13S4G14
4 Membri
14 Guide realizzate
2 Commenti
I have Toshiba E45t-A4300 soft touch screen. The battery is spoilt. The battery compartment is not accessible. How do I remove it and replace it with a new one,?
Benjamin Osei - Replica
The part number is PSUB2U-00K00P
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,336
