Salta al contenuto principale
Toshiba Satellite 2435-S255 Battery Replacement
  1. Toshiba Satellite 2435-S255 Battery Replacement, Removing the Latch: passo 1, immagine 1 di 2 Toshiba Satellite 2435-S255 Battery Replacement, Removing the Latch: passo 1, immagine 2 di 2
    • The latch on this is tricky. Fortunately, it’s the only thing you have to deal with.
    • First, slide the latch until you hit resistance. At this point, you have two options.
    • You can either keep pushing the latch until the battery pops out. . .
    • or you can start prying the battery out while pushing the latch (as shown in the second picture above).
  2. Toshiba Satellite 2435-S255 Battery Replacement, Remove the Battery: passo 2, immagine 1 di 1
    • Just lift the battery up and out, making sure to lift from the end near the latch.
    • Now the battery is out! To put it back, just insert it back in from the same angle you took it out on.
Conclusione
UMass Dartmouth, Team 1-5, Shastany Fall 2014 Membro di UMass Dartmouth, Team 1-5, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G5
3 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 287
