Salta al contenuto principale
Toshiba Satellite 2430-S255 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite 2430-S255 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the battery locking mechanism on the back side of the laptop. It is labeled with a lock and unlock symbol to indicate its function. The mechanism also has a serrated texture to increase grip.
  2. Toshiba Satellite 2430-S255 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Place your left hand on the locking mechanism and slide it all the way to the left. This will move it into the unlocked position. While holding the mechanism in the unlocked position place another finger in the cavity to the right of the locking mechanism.
  3. Toshiba Satellite 2430-S255 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Pulling up with your right hand while the locking mechanism in in the unlocked position will release the battery from its socket.
  4. Toshiba Satellite 2430-S255 Hard Drive Replacement, Optical Disc Drive: passo 4, immagine 1 di 2 Toshiba Satellite 2430-S255 Hard Drive Replacement, Optical Disc Drive: passo 4, immagine 2 di 2
    • Flip your device on its backside.
    • Slide the latch on the bottom left of the backside all the way to the left
    • Keep holding the latch in that position and move to the next step.
  5. Toshiba Satellite 2430-S255 Hard Drive Replacement: passo 5, immagine 1 di 2 Toshiba Satellite 2430-S255 Hard Drive Replacement: passo 5, immagine 2 di 2
    • While holding the latch in place, pull out the Optical Disc Drive towards your body, away from the latch with another hand.
    • The Drive should move smoothly. If it is not movable, the latch may not be pushed all the way to the left.
    • The Drive has friction grids to make pulling it away from the latch easier.
  6. Toshiba Satellite 2430-S255 Hard Drive Replacement, Hard Drive: passo 6, immagine 1 di 2 Toshiba Satellite 2430-S255 Hard Drive Replacement, Hard Drive: passo 6, immagine 2 di 2
    • Locate and unscrew the 4 6mm Phillips Head Screws using a PH 0 Screwdriver bit.
    • This leaves the Hard drive free to move around. Keep the screws in a safe place so you can easily reassemble this part once this guide is finished.
  7. Toshiba Satellite 2430-S255 Hard Drive Replacement: passo 7, immagine 1 di 3 Toshiba Satellite 2430-S255 Hard Drive Replacement: passo 7, immagine 2 di 3 Toshiba Satellite 2430-S255 Hard Drive Replacement: passo 7, immagine 3 di 3
    • Place both thumbs on the bottom end of the hard drive and push it up.
    • Then use both index fingers to grasp the two metal side prongs that were held in place by the screws.
    • Pull out the drive towards your body using your index fingers.
    • Don't lift the hard drive up too high or you might damage the connection between the hard drive and the motherboard.
    • There may be some resistance while pulling the hard drive out of its socket. You may need to apply a small amount of force to move it.
  8. Toshiba Satellite 2430-S255 Hard Drive Replacement: passo 8, immagine 1 di 3 Toshiba Satellite 2430-S255 Hard Drive Replacement: passo 8, immagine 2 di 3 Toshiba Satellite 2430-S255 Hard Drive Replacement: passo 8, immagine 3 di 3
    • After removing the hard drive from the laptop, locate and unscrew the 4 5mm screws (2 on each side) from the rails using a PH 0 screwdriver bit.
    • Remember the orientation of the rails when removing them for easy assembly.
    • Store these screws somewhere safe so that reassembly can be done more quickly and completely.
  9. Toshiba Satellite 2430-S255 Hard Drive Replacement: passo 9, immagine 1 di 2 Toshiba Satellite 2430-S255 Hard Drive Replacement: passo 9, immagine 2 di 2
    • Holding the hard drive in place with the connection facing towards your body, put a finger on the cover and slide it away from your body to reveal the hard drive.
    • Do not spill liquids on or in any way puncture the circuit board or really any part of the hard drive. This could lead to failure in the part and make it hard to repair or even unusable.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
que capacidad de disco duro soporta, ya que le intente instalar uno de 120 pero no me deja formatearla ni ponerle windows
alejandro hernandez sepulveda - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 577
