Salta al contenuto principale
Toshiba Satellite 1805-S177 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite 1805-S177 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 Toshiba Satellite 1805-S177 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Stick a spudger in one of the sides of the top panel. Lift slowly from one side to the other and it will pop off.
  2. Toshiba Satellite 1805-S177 Keyboard Replacement: passo 2, immagine 1 di 3 Toshiba Satellite 1805-S177 Keyboard Replacement: passo 2, immagine 2 di 3 Toshiba Satellite 1805-S177 Keyboard Replacement: passo 2, immagine 3 di 3
    • Using an Phillips screwdriver, unscrew and remove two screws labeled B2.6.
  3. Toshiba Satellite 1805-S177 Keyboard Replacement: passo 3, immagine 1 di 1
    • Using your hands, lift keyboard up toward you, starting from the edge closest to the screen.
    • The keyboard is still connected to the laptop by a ribbon. Place the keyboard gently on top of the trackpad, keys side down.
  4. Toshiba Satellite 1805-S177 Keyboard Replacement: passo 4, immagine 1 di 2 Toshiba Satellite 1805-S177 Keyboard Replacement: passo 4, immagine 2 di 2
    • Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
    • Slide the white ribbon connector up and lift the ribbon out of it.
Conclusione
Hannah
Membro da: 06/24/10
227 Reputazione
7 Guide realizzate
Cal Poly, Team 3-5, Johann Summer 2010 Membro di Cal Poly, Team 3-5, Johann Summer 2010
CPSU-JOHANN-R10S3G5
4 Membri
24 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,660
