Salta al contenuto principale
Toshiba Satellite 1805-S177 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Satellite 1805-S177 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 2 Toshiba Satellite 1805-S177 Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Look at the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove the screw labeled F4, located on the cover of the hard drive.
    • The hard drive is located next to the CD drive.
  2. Toshiba Satellite 1805-S177 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Placing your finger on the raised grip, push up on the hard drive cover. This will remove the hard drive cover from the laptop.
  3. Toshiba Satellite 1805-S177 Hard Drive Replacement: passo 3, immagine 1 di 2 Toshiba Satellite 1805-S177 Hard Drive Replacement: passo 3, immagine 2 di 2
    • Using a Phillips screwdriver, unscrew and remove the screw surrounded by the white plastic.
  4. Toshiba Satellite 1805-S177 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Pull the white plastic out toward you. This should remove the hard drive tray from the laptop.
    • This laptop does not have a hard drive, so the tray is empty. On your computer, the hard drive should be in the tray.
Conclusione
Hannah
Membro da: 06/24/10
227 Reputazione
7 Guide realizzate
Cal Poly, Team 3-5, Johann Summer 2010 Membro di Cal Poly, Team 3-5, Johann Summer 2010
CPSU-JOHANN-R10S3G5
4 Membri
24 Guide realizzate
1Commento della guida
How can I run a cd if I can't remember my hdd password on my toshiba l645 computer
Vera Hess - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 4,248
