Salta al contenuto principale
Toshiba Satellite 1415-S105 Keyboard Replacement
Cosa ti serve
  1. Toshiba Satellite 1415-S105 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • The battery is located on the front right corner of the laptop.
  2. Toshiba Satellite 1415-S105 Keyboard Replacement: passo 2, immagine 1 di 1
    • With one finger on the raised grip, slide the latch towards the front of the laptop.
  3. Toshiba Satellite 1415-S105 Keyboard Replacement: passo 3, immagine 1 di 2 Toshiba Satellite 1415-S105 Keyboard Replacement: passo 3, immagine 2 di 2
    • Pull the battery out towards the side.
  4. Toshiba Satellite 1415-S105 Keyboard Replacement: passo 4, immagine 1 di 2 Toshiba Satellite 1415-S105 Keyboard Replacement: passo 4, immagine 2 di 2
    • Lift the battery straight up, out of the computer.
  5. Toshiba Satellite 1415-S105 Keyboard Replacement, Keyboard: passo 5, immagine 1 di 3 Toshiba Satellite 1415-S105 Keyboard Replacement, Keyboard: passo 5, immagine 2 di 3 Toshiba Satellite 1415-S105 Keyboard Replacement, Keyboard: passo 5, immagine 3 di 3
    • Using a set of case opening tools, pry open the left and right sides of the black plastic strip above the keyboard.
    • Fully detach the strip.
  6. Toshiba Satellite 1415-S105 Keyboard Replacement: passo 6, immagine 1 di 2 Toshiba Satellite 1415-S105 Keyboard Replacement: passo 6, immagine 2 di 2
    • Unscrew the two screws near the top of the keyboard.
  7. Toshiba Satellite 1415-S105 Keyboard Replacement: passo 7, immagine 1 di 2 Toshiba Satellite 1415-S105 Keyboard Replacement: passo 7, immagine 2 di 2
    • Lift the keyboard by holding the middle top of the keyboard.
    • The keyboard is still connected by a ribbon cable to the motherboard.
  8. Toshiba Satellite 1415-S105 Keyboard Replacement: passo 8, immagine 1 di 3 Toshiba Satellite 1415-S105 Keyboard Replacement: passo 8, immagine 2 di 3 Toshiba Satellite 1415-S105 Keyboard Replacement: passo 8, immagine 3 di 3
    • Carefully pull upwards on the ribbon cable to detach.
    • Remove keyboard.
Conclusione
Kiril Lange
Membro da: 09/22/14
943 Reputazione
9 Guide realizzate
USF Tampa, Team 3-2, Brown Fall 2014 Membro di USF Tampa, Team 3-2, Brown Fall 2014
USFT-BROWN-F14S3G2
3 Membri
27 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 332
