Introduzione
This guide gives instructions on how to remove the Right-Side Motherboard (Yellow) of the Toshiba SD-K740 DVD player, which controls the buttons and power function.
Parti
Nessuna parte richiesta.
Make sure the DVD player is unplugged before beginning.
  • Make sure the DVD player is unplugged before beginning.
  • Remove the three .303 inch screws from the back panel using a #0 Phillips head screwdriver.
Aggiungi Commento
Turn the DVD player on its side.
  • Turn the DVD player on its side.
  • Remove the .303 inch screw.
  • Now flip the DVD player onto its other side.
  • Remove the .303 inch screw from this side.
Aggiungi Commento
  • Flip the DVD player over onto it's front face.
  • Remove the back panel by lifting up and pulling it towards yourself.
Aggiungi Commento
  • Flip the DVD player so its top is sitting on your working surface.
  • Lift and push away each of the two tabs located in the middle of the player.
  • The front panel will not come off during this step, so do not force it.
Aggiungi Commento
  • Flip the DVD player on its side.
  • Lift and slide forward a single tab on the side.
Aggiungi Commento
  • Grasp the front panel and pull forward and to your right to remove.
Aggiungi Commento
  • Remove the black tie holding the two rear ribbon cables together by untwisting it.
Aggiungi Commento
  • Remove the first of two ribbon cables connected to the motherboard by pulling vertically.
Aggiungi Commento
  • Remove the second of two ribbon cables connected to the motherboard by pulling vertically.
Aggiungi Commento
  • Pull the two cables to the right to disentangle from the disc drive.
  • Do not tug, pull, or force cable, it should slide out with minimal force.
Aggiungi Commento
  • Pull power cord vertically to detach from the casing.
Aggiungi Commento
  • Remove the three .303 inch screws attaching the inverter board to the casing using a #0 Phillips screwdriver.
Aggiungi Commento
  • Push the inverter board forward and to the left to remove from the holding ledges.
Aggiungi Commento
  • Lift the inverter board from the back end and pull toward you to complete removal.
Aggiungi Commento
Conclusione
Joe Murphy
Membro da: 20/01/2011
542 Reputazione
5 Guide realizzate
Cal Poly, Team 1-16, Amido Winter 2011 Membro di Cal Poly, Team 1-16, Amido Winter 2011
CPSU-AMIDO-W11S1G16
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,879
