Introduzione
This guide gives instructions on how to remove the disc drive of the Toshiba SD-K740 DVD player.
Parti
Nessuna parte richiesta.
  1. Make sure the DVD player is unplugged before beginning.
    • Make sure the DVD player is unplugged before beginning.
    • Remove the three .303 inch screws from the back panel using a #0 Phillips head screwdriver.
  2. Turn the DVD player on its side. Remove the .303 inch screw.
    • Turn the DVD player on its side.
    • Remove the .303 inch screw.
    • Now flip the DVD player onto its other side.
    • Remove the .303 inch screw from this side.
  3. Flip the DVD player over onto it's front face.
    • Flip the DVD player over onto it's front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Flip the DVD player so its top is sitting on your working surface.
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away each of the two tabs located in the middle of the player.
    • The front panel will not come off during this step, so do not force it.
  5. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  6. Flip the DVD player on its side.
    • Flip the DVD player on its side.
    • Lift and slide forward a single tab on the side.
  7. Grasp the front panel and pull forward and to your right to remove. Grasp the front panel and pull forward and to your right to remove.
    • Grasp the front panel and pull forward and to your right to remove.
  8. Remove the first of three ribbon cables on left hand side of disc drive by pulling vertically. Remove the first of three ribbon cables on left hand side of disc drive by pulling vertically.
    • Remove the first of three ribbon cables on left hand side of disc drive by pulling vertically.
  9. Remove the second of three ribbon cables on left hand side of disc drive by pulling vertically. Remove the second of three ribbon cables on left hand side of disc drive by pulling vertically.
    • Remove the second of three ribbon cables on left hand side of disc drive by pulling vertically.
  10. Remove the third of three ribbon cables on left hand side of disc drive by pulling vertically. Remove the third of three ribbon cables on left hand side of disc drive by pulling vertically.
    • Remove the third of three ribbon cables on left hand side of disc drive by pulling vertically.
  11. Remove the four screws holding the disc drive in place using a #0 Phillips screwdriver.
    • Remove the four screws holding the disc drive in place using a #0 Phillips screwdriver.
  12. Lift disc drive vertically to remove.
    • Lift disc drive vertically to remove.
Conclusione
Joe Murphy
Membro da: 20/01/2011
542 Reputazione
5 Guide realizzate
Cal Poly, Team 1-16, Amido Winter 2011 Membro di Cal Poly, Team 1-16, Amido Winter 2011
CPSU-AMIDO-W11S1G16
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,215
