Salta al contenuto principale
Toshiba SD-4980 belt Replacement
Cosa ti serve
  1. Toshiba SD-4980 belt Replacement, cover: passo 1, immagine 1 di 1
    • Five identical screws: three in back, one in each of left and right sides. Cover lifts away. One may call it 'top cover'.
  2. Toshiba SD-4980 belt Replacement, tray: passo 2, immagine 1 di 2 Toshiba SD-4980 belt Replacement, tray: passo 2, immagine 2 di 2
    • Disc tray being open/extended-out is a precondition to access its drive belt.
    • Use a stick to depress optical deck and unclamp spindle. As optical deck lowers, disc tray juts. Pull or push tray toward its out & open position.
  3. Toshiba SD-4980 belt Replacement, belt: passo 3, immagine 1 di 1
    • Replace tray/drive belt.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 505
