Salta al contenuto principale
Toshiba Qosmio X775-3DV80 Optical Drive Replacement
Cosa ti serve
  1. Toshiba Qosmio X775-3DV80 Optical Drive Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Qosmio X775-3DV80 Optical Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Turn your laptop over so the underside is facing up.
  2. Toshiba Qosmio X775-3DV80 Optical Drive Replacement: passo 2, immagine 1 di 2 Toshiba Qosmio X775-3DV80 Optical Drive Replacement: passo 2, immagine 2 di 2
    • Identify the two sliding locks on either side of the battery.
    • Simultaneously slide both locks outward to release the battery.
  3. Toshiba Qosmio X775-3DV80 Optical Drive Replacement: passo 3, immagine 1 di 1
    • Pull the battery straight out of its slot to remove it.
  4. Toshiba Qosmio X775-3DV80 Optical Drive Replacement, Optical Drive: passo 4, immagine 1 di 1
    • Locate the optical drive retaining screw on the underside of the laptop.
  5. Toshiba Qosmio X775-3DV80 Optical Drive Replacement: passo 5, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the optical drive retaining screw.
  6. Toshiba Qosmio X775-3DV80 Optical Drive Replacement: passo 6, immagine 1 di 2 Toshiba Qosmio X775-3DV80 Optical Drive Replacement: passo 6, immagine 2 di 2
    • Using your finger or a spudger, push the optical drive out of its compartment so you can grab it.
    • Pull the optical drive out of its slot in the side of the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 332
