Salta al contenuto principale
Toshiba Qosmio X775-3DV80 Keyboard Replacement
Cosa ti serve
  1. Toshiba Qosmio X775-3DV80 Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Qosmio X775-3DV80 Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Turn your laptop over so the underside is facing up.
  2. Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 2, immagine 1 di 2 Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 2, immagine 2 di 2
    • Identify the two sliding locks on either side of the battery.
    • Simultaneously slide both locks outward to release the battery.
  3. Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 3, immagine 1 di 1
    • Pull the battery straight out of its slot to remove it.
  4. Toshiba Qosmio X775-3DV80 Keyboard Replacement, Optical Drive: passo 4, immagine 1 di 1
    • Locate the optical drive retaining screw on the underside of the laptop.
  5. Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 5, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the optical drive retaining screw.
  6. Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 6, immagine 1 di 2 Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 6, immagine 2 di 2
    • Using your finger or a spudger, push the optical drive out of its compartment so you can grab it.
    • Pull the optical drive out of its slot in the side of the laptop.
  7. Toshiba Qosmio X775-3DV80 Keyboard Replacement, RAM: passo 7, immagine 1 di 1
    • Loosen the single screw on the service panel by twisting counterclockwise with a Phillips #00 screwdriver.
    • It is a captive screw that will remain attached to the service panel.
  8. Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 8, immagine 1 di 1
    • Using a spudger or plastic opening tool, pry off the service panel.
  9. Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 9, immagine 1 di 3 Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 9, immagine 2 di 3 Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 9, immagine 3 di 3
    • Using your fingers, pull the retaining clips away from the RAM sticks.
    • Pull the RAM sticks out of the slots.
  10. Toshiba Qosmio X775-3DV80 Keyboard Replacement, Keyboard: passo 10, immagine 1 di 2 Toshiba Qosmio X775-3DV80 Keyboard Replacement, Keyboard: passo 10, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove all the remaining fourteen screws from the bottom case of the laptop.
    • The service panel should already be removed.
  11. Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 11, immagine 1 di 2 Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 11, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove the five screws under the service panel.
    • Remove the retaining clip.
  12. Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 12, immagine 1 di 1
    • Using a spudger, pry the keyboard from the top panel of the laptop.
    • Make sure to pry it off all around.
  13. Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 13, immagine 1 di 3 Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 13, immagine 2 di 3 Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 13, immagine 3 di 3
    • Disconnect the two ribbon cables connecting the keyboard to the laptop.
    • Unplug the connector on the bottom of the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 22
Tutti i Tempi: 596
