Salta al contenuto principale
Toshiba Portege Z835-P330 Solid-State Drive Replacement
Cosa ti serve
  1. Toshiba Portege Z835-P330 Solid-State Drive Replacement, Solid-State Drive: passo 1, immagine 1 di 1
    • Remove the thirteen 1.4mm screws using a Phillips #2 screwdriver.
  2. Toshiba Portege Z835-P330 Solid-State Drive Replacement: passo 2, immagine 1 di 1
    • Locate hidden screw found in the middle of back hardcover.
    • Found under rubber covering shown in picture.
    • Remove the single Torx Security screw using a TR7 screwdriver.
  3. Toshiba Portege Z835-P330 Solid-State Drive Replacement: passo 3, immagine 1 di 1
    • Peel off hard cover to expose interior of device.
  4. Toshiba Portege Z835-P330 Solid-State Drive Replacement: passo 4, immagine 1 di 1
    • Find the solid-state drive located below the battery, and next to the RAM.
    • Unscrew the two 1mm screws located at the top of the solid-state drive with a Phillips #1 screwdriver.
  5. Toshiba Portege Z835-P330 Solid-State Drive Replacement: passo 5, immagine 1 di 1
    • Pull the solid-state drive from its socket
    • The solid-state drive should automatically pop-up from its housing once the screws are removed.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,212
