Salta al contenuto principale
Toshiba Portege Z835-P330 Battery Replacement
Cosa ti serve
  1. Toshiba Portege Z835-P330 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the thirteen 1.4mm screws on back of device using a Phillips #2 screwdriver.
  2. Toshiba Portege Z835-P330 Battery Replacement: passo 2, immagine 1 di 1
    • Locate hidden screw found in the middle of back hardcover.
    • Found under rubber covering shown in picture.
    • Remove the single Torx Security screw using a TR7 screwdriver.
  3. Toshiba Portege Z835-P330 Battery Replacement: passo 3, immagine 1 di 1
    • Peel off hardcover to expose interior of device.
    • Force may be required but hardcover should detach smoothly.
  4. Toshiba Portege Z835-P330 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the six 1 mm screws using a Phillips #1 screwdriver.
  5. Toshiba Portege Z835-P330 Battery Replacement: passo 5, immagine 1 di 1
    • Remove the white plug connected to the battery by gently pulling it out of the socket.
    • Plug should easily detach without force.
  6. Toshiba Portege Z835-P330 Battery Replacement: passo 6, immagine 1 di 1
    • Lift battery up by its sides, and it should easily come off.
Conclusione
Altre 2 persone hanno completato questa guida.
6 Commenti
These steps also work for the Z935-P300. NOTE: the center screw in step two is a Torx Security TR7.
Jim Flattery - Replica
Will it lose it’s memory when the power and battery are disconnected? Do I need to back it up before I do this? My battery is so dead that the laptop shuts down after just a few minutes without the ac cord plugged in.
Thank you!
pat_brady_pb@yahoo.com - Replica
I suspect you have already completed your repair and now know the answer, however, in the event that you are still waiting on a response. The short answer is no, the storage drive will not loose data when changing the battery. Despite this, it is always wise to have a backup.
Jim Flattery -
Could anyone please tell me which type of screws are these ?
lourencopintodasilva - Replica
Which screws are you referring to? I believe they all have their details size and type listed above. Is there one in particular you need further detail on?
Jim Flattery -
trying to find a CMOS RTC Battery for Toshiba z830 p370, so many options but I don’t know which one is the proper one, I will appreciate any help
ahronee - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 29
Tutti i Tempi: 4,302
