Salta al contenuto principale
Toshiba Portege R835-P88 Screen Replacement
Cosa ti serve
  1. Toshiba Portege R835-P88 Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Remove the battery by pressing the two buttons inward and pulling the battery out.
  2. Toshiba Portege R835-P88 Screen Replacement: passo 2, immagine 1 di 1
    • Remove the end caps located on the left and right corners below the screen.
  3. Toshiba Portege R835-P88 Screen Replacement: passo 3, immagine 1 di 1
    • Remove the square rubber caps on top of the screws
    • Remove the 4 mm screws at the top
    • remove the two 6 mm screws that were under the chrome caps at the bottom.
  4. Toshiba Portege R835-P88 Screen Replacement: passo 4, immagine 1 di 1
    • Remove the plastic bezel by lightly prying on it. It will pop when it starts to come loose.
  5. Toshiba Portege R835-P88 Screen Replacement: passo 5, immagine 1 di 2 Toshiba Portege R835-P88 Screen Replacement: passo 5, immagine 2 di 2
    • Remove tape from around cord attached to the bottom of the screen.
    • Place the screen on top of the keyboard
  6. Toshiba Portege R835-P88 Screen Replacement: passo 6, immagine 1 di 3 Toshiba Portege R835-P88 Screen Replacement: passo 6, immagine 2 di 3 Toshiba Portege R835-P88 Screen Replacement: passo 6, immagine 3 di 3
    • Remove the cord from the screen by cutting the tape where the two fittings meet. After that pull them apart.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 447
