Salta al contenuto principale
Toshiba Portege R835-P88 Optical Drive Replacement
Cosa ti serve
  1. Toshiba Portege R835-P88 Optical Drive Replacement, Optical Drive: passo 1, immagine 1 di 1
    • Start by removing the battery.
  2. Toshiba Portege R835-P88 Optical Drive Replacement: passo 2, immagine 1 di 2 Toshiba Portege R835-P88 Optical Drive Replacement: passo 2, immagine 2 di 2
    • Start by removing the back cover by removing the screws, revealing the Optical Drive. Remove the 1 cm screws to remove. Then use the spudger to pry the back off.
  3. Toshiba Portege R835-P88 Optical Drive Replacement: passo 3, immagine 1 di 1
    • After the cover is removed, remove the screws that hold the Drive. It has 3, 1 cm screws holding it down.
  4. Toshiba Portege R835-P88 Optical Drive Replacement: passo 4, immagine 1 di 1
    • Take the 2, .5 cm screws out of the drive line. Once this is complete, you have successfully taken out the Optical Drive.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 666
