Salta al contenuto principale
Toshiba Portege R705-P35 DVD Drive Replacement
Cosa ti serve
  1. Toshiba Portege R705-P35 DVD Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off and unplug the laptop.
    • Failure to turn off and unplug the cable could result in electric shock.
    • Place the laptop upside-side-down with the hinges towards you.
  2. Toshiba Portege R705-P35 DVD Drive Replacement: passo 2, immagine 1 di 1
    • Use your right hand to move the right switch from the locked position to the unlocked position.
    • Use your left hand to move the left switch from the locked position to the unlocked position.
  3. Toshiba Portege R705-P35 DVD Drive Replacement: passo 3, immagine 1 di 2 Toshiba Portege R705-P35 DVD Drive Replacement: passo 3, immagine 2 di 2
    • While keeping the left switch unlocked, pull the battery away from the computer with your right hand.
  4. Toshiba Portege R705-P35 DVD Drive Replacement, RAM Plate: passo 4, immagine 1 di 3 Toshiba Portege R705-P35 DVD Drive Replacement, RAM Plate: passo 4, immagine 2 di 3 Toshiba Portege R705-P35 DVD Drive Replacement, RAM Plate: passo 4, immagine 3 di 3
    • Loosen the two captive screws in the plate with a Phillips #00 screwdriver.
    • Remove the plate from the laptop.
  5. Toshiba Portege R705-P35 DVD Drive Replacement, Hard Drive Plate: passo 5, immagine 1 di 1
    • Loosen the two captive screws in the hard drive plate using a Phillips #00 screwdriver.
  6. Toshiba Portege R705-P35 DVD Drive Replacement: passo 6, immagine 1 di 2 Toshiba Portege R705-P35 DVD Drive Replacement: passo 6, immagine 2 di 2
    • Use your hands to remove the hard drive plate from the laptop.
  7. Toshiba Portege R705-P35 DVD Drive Replacement, Back Plate: passo 7, immagine 1 di 1
    • Remove the two 13 mm screws from the back plate using a Phillips #0 screwdriver.
  8. Toshiba Portege R705-P35 DVD Drive Replacement: passo 8, immagine 1 di 2 Toshiba Portege R705-P35 DVD Drive Replacement: passo 8, immagine 2 di 2
    • Lift and remove the small plate from the laptop.
  9. Toshiba Portege R705-P35 DVD Drive Replacement: passo 9, immagine 1 di 1
    • Remove the thirteen 6 mm screws from the back plate using a Phillips #00 screwdriver.
    • Remove the five 5 mm screws from the back plate using a Phillips #00 screwdriver.
  10. Toshiba Portege R705-P35 DVD Drive Replacement: passo 10, immagine 1 di 2 Toshiba Portege R705-P35 DVD Drive Replacement: passo 10, immagine 2 di 2
    • Pull the back plate off, starting from the right side, being cautious of the ports on the left side.
  11. Toshiba Portege R705-P35 DVD Drive Replacement, DVD Drive: passo 11, immagine 1 di 2 Toshiba Portege R705-P35 DVD Drive Replacement, DVD Drive: passo 11, immagine 2 di 2
    • Use an opening tool to detach the hard drive connector from the DVD drive.
  12. Toshiba Portege R705-P35 DVD Drive Replacement: passo 12, immagine 1 di 3 Toshiba Portege R705-P35 DVD Drive Replacement: passo 12, immagine 2 di 3 Toshiba Portege R705-P35 DVD Drive Replacement: passo 12, immagine 3 di 3
    • Remove the two 4 mm screws using a Phillips #00 screwdriver.
    • Remove the one 3 mm screw using a Phillips #00 screwdriver.
    • Remove the silver bracket that comes loose.
  13. Toshiba Portege R705-P35 DVD Drive Replacement: passo 13, immagine 1 di 3 Toshiba Portege R705-P35 DVD Drive Replacement: passo 13, immagine 2 di 3 Toshiba Portege R705-P35 DVD Drive Replacement: passo 13, immagine 3 di 3
    • Pull on the orange bar with your fingers to detach it from the DVD drive.
    • Pull out and remove the DVD drive from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 185
