Salta al contenuto principale
Toshiba Portege R705-P35 Battery Replacement
  1. Toshiba Portege R705-P35 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off and unplug the laptop.
    • Failure to turn off and unplug the cable could result in electric shock.
    • Place the laptop upside-side-down with the hinges towards you.
  2. Toshiba Portege R705-P35 Battery Replacement: passo 2, immagine 1 di 1
    • Use your right hand to move the right switch from the locked position to the unlocked position.
    • Use your left hand to move the left switch from the locked position to the unlocked position.
  3. Toshiba Portege R705-P35 Battery Replacement: passo 3, immagine 1 di 2 Toshiba Portege R705-P35 Battery Replacement: passo 3, immagine 2 di 2
    • While keeping the left switch unlocked, pull the battery away from the computer with your right hand.
Conclusione
Un commento
My battery can't resist more than 15 min
massilia.10 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 273
