Salta al contenuto principale
Toshiba Portege R700-S1312 Hard Drive Replacement
Cosa ti serve
  1. Toshiba Portege R700-S1312 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the battery on the backside of the laptop. The battery is usually located at the bottom.
  2. Toshiba Portege R700-S1312 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Locate the battery lock button and push it towards the unlock position.
  3. Toshiba Portege R700-S1312 Hard Drive Replacement: passo 3, immagine 1 di 3 Toshiba Portege R700-S1312 Hard Drive Replacement: passo 3, immagine 2 di 3 Toshiba Portege R700-S1312 Hard Drive Replacement: passo 3, immagine 3 di 3
    • Hold the next lock in the unlock position. Simultaneously pull the battery towards you.
  4. Toshiba Portege R700-S1312 Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 1
    • Remove the 40 mm screws from the RAM cover using a Phillips #00 Screwdriver.
  5. Toshiba Portege R700-S1312 Hard Drive Replacement: passo 5, immagine 1 di 1
    • Lift and remove the RAM cover to reveal the first of 2 40mm screws holding down the hard drive cover. Remove the screw using a Phillips #00 Screwdriver.
  6. Toshiba Portege R700-S1312 Hard Drive Replacement: passo 6, immagine 1 di 1
    • Remove the second 40mm hard drive cover screw using a Phillips #00 Screwdriver.
  7. Toshiba Portege R700-S1312 Hard Drive Replacement: passo 7, immagine 1 di 1
    • Lift and remove the hard drive cover.
  8. Toshiba Portege R700-S1312 Hard Drive Replacement: passo 8, immagine 1 di 1
    • Connect the drive (in this case a solid state drive) to the laptop using the SATA cable located inside the hard drive placement area.
  9. Toshiba Portege R700-S1312 Hard Drive Replacement: passo 9, immagine 1 di 1
    • Once the drive is connected, carefully insert the drive into the laptop enclosure.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 45
Tutti i Tempi: 2,728
