Salta al contenuto principale
Toshiba Portege R500 Wi-FI Card Replacement
Cosa ti serve
  1. Toshiba Portege R500 Wi-FI Card Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Portege R500 Wi-FI Card Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure the device is off to prevent data loss.
    • Slide both latches to the unlocked position to release the battery.
    • Switch the latch on the right to reveal red. The latch on the left needs to be held.
    • Pull the battery toward you while holding the left latch.
  2. Toshiba Portege R500 Wi-FI Card Replacement, Wi-FI Card: passo 2, immagine 1 di 1
    • Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
  3. Toshiba Portege R500 Wi-FI Card Replacement: passo 3, immagine 1 di 1
    • Pull up on the back casing and remove it, revealing the Wi-Fi card.
  4. Toshiba Portege R500 Wi-FI Card Replacement: passo 4, immagine 1 di 2 Toshiba Portege R500 Wi-FI Card Replacement: passo 4, immagine 2 di 2
    • Unscrew the two 3.5 mm screws from the Wi-Fi card with the Phillips 00 screwdriver.
    • Pull the Wi-Fi card towards the battery slot to release it.
  5. Toshiba Portege R500 Wi-FI Card Replacement: passo 5, immagine 1 di 1
    • Remove the three wires from the Wi-Fi card by pulling them straight up and off.
    • The Wi-Fi card should now be free of the laptop.
    • When removing the wires be sure to remember which wire came from which port, consider marking them so that you can remember.
Conclusione
JRJones
Membro da: 04/19/13
169 Reputazione
5 Guide realizzate
Cal Poly, Team 2-19, Maness Spring 2013 Membro di Cal Poly, Team 2-19, Maness Spring 2013
CPSU-MANESS-S13S2G19
3 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,278
