Salta al contenuto principale
Introduzione
In this guide we will be dissembling the device so that we can replace the fan in the laptop.
  1. Make sure the device is off to prevent data loss. Slide both latches to the unlocked position to release the battery.
    • Make sure the device is off to prevent data loss.
    • Slide both latches to the unlocked position to release the battery.
    • Switch the latch on the right to reveal red. The latch on the left needs to be held.
    • Pull the battery toward you while holding the left latch.
  2. Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
    • Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
  3. Kits di riparazione iPhone X
    Garanzia finita? Non preoccuparti, abbiamo la soluzione.
    Acquista ora
    Acquista ora
  4. Pull up on the back casing and remove it.
    • Pull up on the back casing and remove it.
  5. Remove the two 5.5 mm screws from the fan with the Phillips 00 screwdriver.
    • Remove the two 5.5 mm screws from the fan with the Phillips 00 screwdriver.
  6. Disconnect the fan's power connector using the rounded handle plastic opening tool.
    • Disconnect the fan's power connector using the rounded handle plastic opening tool.
    • The fan should now be free of the laptop and can be removed.
Conclusione
JRJones
Membro da: 19/04/2013
121 Reputazione
5 Guide realizzate
Cal Poly, Team 2-19, Maness Spring 2013 Membro di Cal Poly, Team 2-19, Maness Spring 2013
CPSU-MANESS-S13S2G19
3 Membri
5 Guide realizzate
Don't forget the silver compound when re-assembling
Graham Smith - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,041
