Salta al contenuto principale
Toshiba Portege R500 CD Drive Replacement
Cosa ti serve
  1. Toshiba Portege R500 CD Drive Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Portege R500 CD Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure the device is off to prevent data loss.
    • Slide both latches to the unlocked position to release the battery.
    • Switch the latch on the right to reveal red. The latch on the left needs to be held.
    • Pull the battery toward you while holding the left latch.
  2. Toshiba Portege R500 CD Drive Replacement, CD Drive: passo 2, immagine 1 di 1
    • Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
  3. Toshiba Portege R500 CD Drive Replacement: passo 3, immagine 1 di 2 Toshiba Portege R500 CD Drive Replacement: passo 3, immagine 2 di 2
    • Pull up on the back casing and remove it, revealing the CD drive.
  4. Toshiba Portege R500 CD Drive Replacement: passo 4, immagine 1 di 1
    • Flip the CD Drive over carefully, lifting the right side and turning the drive in order to reveal the attachment.
  5. Toshiba Portege R500 CD Drive Replacement: passo 5, immagine 1 di 2 Toshiba Portege R500 CD Drive Replacement: passo 5, immagine 2 di 2
    • Rotate the laptop ninety degrees so the screws and connection are visible.
    • Remove the two 4 mm screws with the Phillips 00 screwdriver.
    • Pull the ribbon cable away from the laptop to release the CD drive from the computer.
    • A small metal divider may fall when you remove the ribbon cable. It needs to be reattached in between the ribbon cable and the drive when the new drive is put in.
Conclusione
JRJones
Membro da: 04/19/13
169 Reputazione
5 Guide realizzate
Cal Poly, Team 2-19, Maness Spring 2013 Membro di Cal Poly, Team 2-19, Maness Spring 2013
CPSU-MANESS-S13S2G19
3 Membri
15 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,943
