Salta al contenuto principale
Toshiba Portege R205-S209 Keyboard Replacement
Cosa ti serve
  1. Toshiba Portege R205-S209 Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Portege R205-S209 Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the laptop over. Keep the front end facing away from you, so the battery appears at the top.
  2. Toshiba Portege R205-S209 Keyboard Replacement: passo 2, immagine 1 di 2 Toshiba Portege R205-S209 Keyboard Replacement: passo 2, immagine 2 di 2
    • Slide the locking mechanism to the right and hold.
  3. Toshiba Portege R205-S209 Keyboard Replacement: passo 3, immagine 1 di 2 Toshiba Portege R205-S209 Keyboard Replacement: passo 3, immagine 2 di 2
    • While holding the locking mechanism to the right, insert your finger into the tab and lift up.
  4. Toshiba Portege R205-S209 Keyboard Replacement: passo 4, immagine 1 di 2 Toshiba Portege R205-S209 Keyboard Replacement: passo 4, immagine 2 di 2
    • Remove battery by lifting upward.
  5. Toshiba Portege R205-S209 Keyboard Replacement, Keyboard: passo 5, immagine 1 di 2 Toshiba Portege R205-S209 Keyboard Replacement, Keyboard: passo 5, immagine 2 di 2
    • Remove the 4mm Phillips head screw in the middle of the laptop with a Phillips head #00 screwdriver.
  6. Toshiba Portege R205-S209 Keyboard Replacement: passo 6, immagine 1 di 1
    • Flip the laptop over and open the display.
  7. Toshiba Portege R205-S209 Keyboard Replacement: passo 7, immagine 1 di 3 Toshiba Portege R205-S209 Keyboard Replacement: passo 7, immagine 2 di 3 Toshiba Portege R205-S209 Keyboard Replacement: passo 7, immagine 3 di 3
    • Remove the plastic casing above the keyboard with the plastic opening tool. Start at the edges of the plastic casing and move toward the middle.
  8. Toshiba Portege R205-S209 Keyboard Replacement: passo 8, immagine 1 di 1
    • Lift up and remove the plastic casing.
  9. Toshiba Portege R205-S209 Keyboard Replacement: passo 9, immagine 1 di 2 Toshiba Portege R205-S209 Keyboard Replacement: passo 9, immagine 2 di 2
    • Remove the 4mm Phillips head screws at the top of the keyboard at both ends, using the Phillips head #00 screwdriver.
  10. Toshiba Portege R205-S209 Keyboard Replacement: passo 10, immagine 1 di 1
    • Lift up the keyboard, but do not remove it completely.
    • The keyboard is still attached to the computer, so be very careful when lifting it up.
  11. Toshiba Portege R205-S209 Keyboard Replacement: passo 11, immagine 1 di 2 Toshiba Portege R205-S209 Keyboard Replacement: passo 11, immagine 2 di 2
    • Gently pull the ribbon toward the screen until it slides out of the connecting point.
    • Remove keyboard.
Conclusione
Leah Catania
Membro da: 10/12/15
113 Reputazione
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 23
Tutti i Tempi: 376
