Salta al contenuto principale
Toshiba Portege M400 Screen Replacement
Cosa ti serve
  1. Toshiba Portege M400 Screen Replacement, Screen: passo 1, immagine 1 di 2 Toshiba Portege M400 Screen Replacement, Screen: passo 1, immagine 2 di 2
    • Using a plastic opening tool, remove all stickers covering the screws.
    • Note: There are 6 locations; 2 at the top corners, 2 at the bottom corners, and 2 more at the bottom, towards the center of the screen.
  2. Toshiba Portege M400 Screen Replacement: passo 2, immagine 1 di 2 Toshiba Portege M400 Screen Replacement: passo 2, immagine 2 di 2
    • Remove all six 3.8mm screws from the screen using a #1 Phillips screwdriver.
  3. Toshiba Portege M400 Screen Replacement: passo 3, immagine 1 di 2 Toshiba Portege M400 Screen Replacement: passo 3, immagine 2 di 2
    • With a plastic opening tool, prop the plastic panel up to separate it from the rest of the laptop.
    • Slowly pull the plastic panel from the entire laptop.
  4. Toshiba Portege M400 Screen Replacement: passo 4, immagine 1 di 2 Toshiba Portege M400 Screen Replacement: passo 4, immagine 2 di 2
    • Remove the four 5 mm screws with a Phillips #1 screwdriver, each located at the four corners of the screen.
  5. Toshiba Portege M400 Screen Replacement: passo 5, immagine 1 di 2 Toshiba Portege M400 Screen Replacement: passo 5, immagine 2 di 2
    • Carefully lift up the screen from the rest of the laptop and let it lean towards you, as it is still attached to cords and other wirings.
    • Remove all white tape that hold the cords and wirings together.
  6. Toshiba Portege M400 Screen Replacement: passo 6, immagine 1 di 2 Toshiba Portege M400 Screen Replacement: passo 6, immagine 2 di 2
    • Note: Some parts need unplugging. Slowly and carefully unplug each of the components.
  7. Toshiba Portege M400 Screen Replacement: passo 7, immagine 1 di 1
    • At this point, the screen should be completely disconnected from the rest of the laptop.
Conclusione
Cal Poly, Team 4-17, Maness Spring 2013 Membro di Cal Poly, Team 4-17, Maness Spring 2013
CPSU-MANESS-S13S4G17
3 Membri
12 Guide realizzate
Un commento
Be careful with this procedure, as there are at least 2 different part numbers for the M400, LTD121KM7K has a 32 pin connector, and a different one, LTD121KC6K has a shorter connector for the display which is not compatible. When ordering from Ebay they do not distinguish between them. I would also like a procedure for replacing the complete screen and lid assembly. I can't find it on the net at the moment. Also, be aware that there may be compatibility issues there too.
Elizabeth Donavan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,511
