Salta al contenuto principale
Toshiba Portege M300 Wireless Card Replacement
Cosa ti serve
  1. Toshiba Portege M300 Wireless Card Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the computer over onto its back.
  2. Toshiba Portege M300 Wireless Card Replacement: passo 2, immagine 1 di 2 Toshiba Portege M300 Wireless Card Replacement: passo 2, immagine 2 di 2
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Toshiba Portege M300 Wireless Card Replacement: passo 3, immagine 1 di 2 Toshiba Portege M300 Wireless Card Replacement: passo 3, immagine 2 di 2
    • Remove the battery by sliding it away from the laptop.
    • Make sure the two locks from the previous step are in the unlocked position while sliding the battery away.
  4. Toshiba Portege M300 Wireless Card Replacement, Wireless Card: passo 4, immagine 1 di 3 Toshiba Portege M300 Wireless Card Replacement, Wireless Card: passo 4, immagine 2 di 3 Toshiba Portege M300 Wireless Card Replacement, Wireless Card: passo 4, immagine 3 di 3
    • Turn the computer onto the back.
    • Remove the Phillips #0 screw that secures the cover to the rest of the device.
    • One 5.1 mm coarse thread screw.
    • Pull the cover forward to release it.
  5. Toshiba Portege M300 Wireless Card Replacement: passo 5, immagine 1 di 3 Toshiba Portege M300 Wireless Card Replacement: passo 5, immagine 2 di 3 Toshiba Portege M300 Wireless Card Replacement: passo 5, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the two screws on opposite corners of the wireless card.
    • Two 4.0 mm coarse thread screws.
    • Use a plastic opening tool to gently lift the wireless card out while leaving the wire connected.
  6. Toshiba Portege M300 Wireless Card Replacement: passo 6, immagine 1 di 2 Toshiba Portege M300 Wireless Card Replacement: passo 6, immagine 2 di 2
    • Hold the edges of the wireless card and carefully disconnect the black 3 pin connector.
Conclusione
Alison Wendt
Membro da: 04/18/13
135 Reputazione
6 Guide realizzate
Cal Poly, Team 21-51, Johann Spring 2013 Membro di Cal Poly, Team 21-51, Johann Spring 2013
CPSU-JOHANN-S13S21G51
3 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 13
Tutti i Tempi: 869
