Salta al contenuto principale
Toshiba Portege M300 LCD Replacement
Cosa ti serve
  1. Toshiba Portege M300 LCD Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the computer over onto its back.
  2. Toshiba Portege M300 LCD Replacement: passo 2, immagine 1 di 2 Toshiba Portege M300 LCD Replacement: passo 2, immagine 2 di 2
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Toshiba Portege M300 LCD Replacement: passo 3, immagine 1 di 2 Toshiba Portege M300 LCD Replacement: passo 3, immagine 2 di 2
    • Remove the battery by sliding it away from the laptop.
    • Make sure the two locks from the previous step are in the unlocked position while sliding the battery away.
  4. Toshiba Portege M300 LCD Replacement, LCD: passo 4, immagine 1 di 2 Toshiba Portege M300 LCD Replacement, LCD: passo 4, immagine 2 di 2
    • Use a plastic opening tool to unsnap the right hand side speaker cover.
  5. Toshiba Portege M300 LCD Replacement: passo 5, immagine 1 di 2 Toshiba Portege M300 LCD Replacement: passo 5, immagine 2 di 2
    • Remove the rest of the cover by sliding it to the right and lifting the right edge.
  6. Toshiba Portege M300 LCD Replacement: passo 6, immagine 1 di 2 Toshiba Portege M300 LCD Replacement: passo 6, immagine 2 di 2
    • Remove all eight plastic circular covers on the plastic screen bezel.
    • Only seven of these plastic covers will contain screws underneath.
    • Unscrew all seven screws with a Phillips head #000 screwdriver.
  7. Toshiba Portege M300 LCD Replacement: passo 7, immagine 1 di 2 Toshiba Portege M300 LCD Replacement: passo 7, immagine 2 di 2
    • Use a plastic opening tool to separate the screen bezel from the rest of the case.
    • Pull at the top edge of the LCD to separate it from the top part of the case.
    • Only separate the casing and the LCD by an inch—there are still wires connecting them.
  8. Toshiba Portege M300 LCD Replacement: passo 8, immagine 1 di 2 Toshiba Portege M300 LCD Replacement: passo 8, immagine 2 di 2
    • Use a Phillips #000 to unscrew the one 2.8 mm fine thread screw holding the wire connected to the right face of the LCD.
  9. Toshiba Portege M300 LCD Replacement: passo 9, immagine 1 di 1
    • Flip the LCD over onto the back.
    • Gently pull the connection on the corner of the LCD to disconnect.
  10. Toshiba Portege M300 LCD Replacement: passo 10, immagine 1 di 2 Toshiba Portege M300 LCD Replacement: passo 10, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the tape connecting LCD to the inverter.
    • Use tweezers to remove the LCD cable from the inverter.
Conclusione
Alison Wendt
Membro da: 04/18/13
135 Reputazione
6 Guide realizzate
Cal Poly, Team 21-51, Johann Spring 2013 Membro di Cal Poly, Team 21-51, Johann Spring 2013
CPSU-JOHANN-S13S21G51
3 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,025
