Salta al contenuto principale
Toshiba NB255-N250 Battery Replacement
Cosa ti serve
  1. Toshiba NB255-N250 Battery Replacement, Power off the Toshiba NB255-N250: passo 1, immagine 1 di 2 Toshiba NB255-N250 Battery Replacement, Power off the Toshiba NB255-N250: passo 1, immagine 2 di 2
    • Before starting any repairs, make sure to power off your device.
    • To shut down the Toshiba NB255-N250, follow the instructions for your operating system or press and hold the power button until the screen turns off.
  2. Toshiba NB255-N250 Battery Replacement, Remove the Battery: passo 2, immagine 1 di 3 Toshiba NB255-N250 Battery Replacement, Remove the Battery: passo 2, immagine 2 di 3 Toshiba NB255-N250 Battery Replacement, Remove the Battery: passo 2, immagine 3 di 3
    • Move the two battery retaining tabs to the opposite sides of the device, then pull the battery straight out the back of the device.
Conclusione
To reassemble your device, open the new battery and follow these instructions in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 21
Tutti i Tempi: 398
