Cosa ti serve
Start by first removing the battery.
Move the first release switch to the right position.
Move the second release switch to the right position while pulling the battery towards the top of the netbook.
Use the spudger to gently pry around the seam of the keyboard. This will release the keyboard assembly from the body.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Pull the cable away from the connector in the same direction as the individual wires using your hands or tweezers.
Use a spudger to gently pry the bezel from retaining clips.
This will allow the keyboard bezel to lift off of the body.
