1. Use a bit driver and a Phillips #0 bit to remove the one 5 mm retaining screw. Lift the panel up and out of the way.
    • Use a bit driver and a Phillips #0 bit to remove the one 5 mm retaining screw.
    • Lift the panel up and out of the way.
  2. The RAM chip is secured by two retaining arms that run parallel with the chip. Gently pull these arms in opposite directions off of the chip. After the retainer arms are free, push the chip towards the top of the netbook. This will free the chip for removal. After the retainer arms are free, push the chip towards the top of the netbook. This will free the chip for removal.
    • The RAM chip is secured by two retaining arms that run parallel with the chip. Gently pull these arms in opposite directions off of the chip.
    • After the retainer arms are free, push the chip towards the top of the netbook. This will free the chip for removal.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Push the replacement RAM into the original position. Reattach both securing arms onto the sides of the RAM chip.
    • Push the replacement RAM into the original position.
    • Reattach both securing arms onto the sides of the RAM chip.
  5. Place the panel back into the securing slots and let it rest in its original position. With the bit driver and Phillips #0 bit, secure the panel down with one screw.
    • Place the panel back into the securing slots and let it rest in its original position.
    • With the bit driver and Phillips #0 bit, secure the panel down with one screw.
Conclusione
Mason McCaskill
Membro da: 18/10/2013
943 Reputazione
9 Guide realizzate
Clemson, Team 14-2, Benson Fall 2013 Membro di Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
3 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 296
